尚维国际的模组到了,开箱使用。
最近项目上涉及一部分模组,因此入坑,前期还比较谨慎,最近本着时间就是金钱的想法,开始陆续入手不少板子和镜头。之前有事没事在淘宝上搜索新唐、君正、全志、松翰的板子。正巧站主也发了一个链接https://whycan.cn/t_1839.html,遂入手。
先上照片:
让店主配块灯板,好大一块板,有需要再装吧。
淘宝展示的资料有问题,接线如下:
客户端读取视频时功耗对比:
其中左侧为不接负载;中为尚维T30;右为雄迈Hi3518EV。
接上串口:
板载Test串口从上到下定义依次为:
1 - UART1_TXD
2 - UART1_RXD
3 - GND
4 - UART_RTS(猜测,未验证)
5 - UART_CTS(猜测,未验证)
启动日志:
U-Boot SPL 2013.07 (Jan 26 2018 - 14:37:18)
Timer init
CLK stop
PLL init
pll_init:411
pll_cfg.pdiv = 10, pll_cfg.h2div = 5, pll_cfg.h0div = 5, pll_cfg.cdiv = 1, pll_cfg.l2div = 2
fbdiv = 62 , refdiv = 1 , fdivq = 4 ,pllod = 2 range = 3
cppcr is 03d01060
CPM_CPAPCR 07c0504d
fbdiv = 42 , refdiv = 1 , fdivq = 2 ,pllod = 1 range = 3
cppcr is 02900860
CPM_CPMPCR 07c0882d
fbdiv = 50 , refdiv = 1 , fdivq = 2 ,pllod = 1 range = 3
cppcr is 03100860
CPM_CPVPCR 0310086d
cppcr is 03100860
CPM_CPEPCR 0310086d
cppcr 0x9a773310
apll_freq 750000000
mpll_freq 1000000000
vpll_freq = 1200000000 epll = 1200000000
ddr sel mpll, cpu sel apll
ddrfreq 500000000
cclk 750000000
l2clk 375000000
h0clk 200000000
h2clk 200000000
pclk 100000000
CLK init
SDRAM init
sdram init start
ddr_inno_phy_init ..!
phy reg = 0x00000007, CL = 0x00000007
ddr_inno_phy_init ..! 11: 00000004
ddr_inno_phy_init ..! 22: 00000006
ddr_inno_phy_init ..! 33: 00000006
REG_DDR_LMR: 00000210
REG_DDR_LMR: 00000310
REG_DDR_LMR: 00000110
REG_DDR_LMR, MR0: 00e73011
T30_0x5: 00000007
T30_0x15: 0000000c
T30_0x4: 00000000
T30_0x14: 00000002
INNO_TRAINING_CTRL 1: 00000000
INNO_TRAINING_CTRL 2: 000000a1
T30_cc: 00000003
INNO_TRAINING_CTRL 3: 000000a0
T30_190: 0000001d
T30_194: 0000001d
jz-04 : 0x00000051
jz-08 : 0x000000a0
jz-28 : 0x00000024
DDR PHY init OK
INNO_DQ_WIDTH :00000003
INNO_PLL_FBDIV :00000014
INNO_PLL_PDIV :00000005
INNO_MEM_CFG :00000051
INNO_PLL_CTRL :00000018
INNO_CHANNEL_EN :0000000d
INNO_CWL :00000006
INNO_CL :00000007
DDR Controller init
DDRC_STATUS 0x80000001
DDRC_CFG 0x0a688a40
DDRC_CTRL 0x0000891c
DDRC_LMR 0x00000000
DDRC_DLP 0x00000000
DDRC_TIMING1 0x040e0806
DDRC_TIMING2 0x02170707
DDRC_TIMING3 0x2007051e
DDRC_TIMING4 0x1a240031
DDRC_TIMING5 0xff060405
DDRC_TIMING6 0x32170505
DDRC_REFCNT 0x00f2b601
DDRC_MMAP0 0x000020fc
DDRC_MMAP1 0x00002400
DDRC_REMAP1 0x03020100
DDRC_REMAP2 0x07060504
DDRC_REMAP3 0x0b0a0908
DDRC_REMAP4 0x0f0e0d0c
DDRC_REMAP5 0x13121110
DDRC_AUTOSR_EN 0x00000000
sdram init finished
SDRAM init ok
board_init_r
image entry point: 0x80100000
U-Boot 2013.07 (Jan 26 2018 - 14:37:18)
Board: ISVP (Ingenic XBurst T30 SoC)
DRAM: 64 MiB
Top of RAM usable for U-Boot at: 84000000
Reserving 705k for U-Boot at: 83f4c000
Reserving 32772k for malloc() at: 81f4b000
Reserving 32 Bytes for Board Info at: 81f4afe0
Reserving 124 Bytes for Global Data at: 81f4af64
Reserving 128k for boot params() at: 81f2af64
Stack Pointer at: 81f2af48
Now running in RAM - U-Boot at: 83f4c000
MMC: msc: 0
the manufacturer 1c
SF: Detected EN25QH64
In: serial
Out: serial
Err: serial
gpio_request lable = PHY RESET gpio = 60
gpio_request lable = IR-CUT-1 gpio = 72
gpio_request lable = IR-CUT-2 gpio = 73
Net: Jz4775-9161
id1=0x243,id2=0xc54
saveaddr: 83fff000
the manufacturer 1c
jz_init......
Bus Mode Reg after write: 0x00020100
====>PHY not found!
GMAC init finish
OurPort: 2051
starting...
time out resend: 0
time out resend: 1
time out resend: 2
JVUpdTimeout When CMD_TRY
netupdate - net update, MODEL just like JVS-HI3518C.
Usage:
netupdate netupdate [MODEL] [SAVEDADDR] [CFGOFFSET] [CFGSIZE]
Just like this:
netupdate JVS-HI3518C 0x83FFF000 0x780000 0x80000
the manufacturer 1c
--->probe spend 4 ms
SF: 1769472 bytes @ 0x4c0000 Read: OK
--->read spend 230 ms
## Booting kernel from Legacy Image at 80600000 ...
Image Name: Linux-3.10.14__isvp_monkey_1.0__
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 1689016 Bytes = 1.6 MiB
Load Address: 80010000
Entry Point: 803a6920
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.14__isvp_monkey_1.0__ (devin@swdev) (gcc version 4.7.2 (Ingenic r2.3.3 2016.12) ) #1 PREEMPT Fri Mar 30 18:44:32 CST 2018
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU0 RESET ERROR PC:02404846
[ 0.000000] CPU0 revision is: 00d00100 (Ingenic Xburst)
[ 0.000000] FPU revision is: 00b70000
[ 0.000000] CCLK:750MHz L2CLK:375Mhz H0CLK:250MHz H2CLK:250Mhz PCLK:125Mhz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 004c0000 @ 00010000 (usable)
[ 0.000000] memory: 00040000 @ 004d0000 (usable after init)
[ 0.000000] User-defined physical RAM map:
[ 0.000000] memory: 02c00000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x00000000-0x02bfffff]
[ 0.000000] node 0: [mem 0x00000000-0x02bfffff]
[ 0.000000] Primary instruction cache 32kB, 8-way, VIPT, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 8-way, VIPT, no aliases, linesize 32 bytes
[ 0.000000] pls check processor_id[0x00d00100],sc_jz not support!
[ 0.000000] MIPS secondary cache 128kB, 8-way, linesize 32 bytes.
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pages: 11176
[ 0.000000] Kernel command line: console=ttyS1,115200n8 mem=44M@0x0 rmem=20M@0x2c00000 init=/linuxrc rootfstype=squashfs root=/dev/mtdblock3 rw mtdparts=jz_sfc:256k(boot),4608k(appfs),1728k(kernel),1024k(root),64k(hwconfig),512k(config)
[ 0.000000] Memory: 38868k/45056k available (3709k kernel code, 6188k reserved, 1154k data, 256k init, 0k highmem)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:418
[ 0.000000] clockevents_config_and_register success.
[ 0.000028] Calibrating delay loop... 743.83 BogoMIPS (lpj=3719168)
[ 0.037702] pid_max: default: 32768 minimum: 301
[ 0.042734] Mount-cache hash table entries: 512
[ 0.047930] Initializing cgroup subsys debug
[ 0.052194] Initializing cgroup subsys freezer
[ 0.059505] regulator-dummy: no parameters
[ 0.063775] NET: Registered protocol family 16
[ 0.086552] bio: create slab <bio-0> at 0
[ 0.093218] jz-dma jz-dma: JZ SoC DMA initialized
[ 0.098405] usbcore: registered new interface driver usbfs
[ 0.103944] usbcore: registered new interface driver hub
[ 0.109474] usbcore: registered new device driver usb
[ 0.114720] i2c-gpio i2c-gpio.1: using pins 57 (SDA) and 58 (SCL)
[ 0.120990] (null): set:311 hold:312 dev=125000000 h=625 l=625
[ 0.127150] media: Linux media interface: v0.10
[ 0.131710] Linux video capture interface: v2.00
[ 0.138743] Switching to clocksource jz_clocksource
[ 0.144389] jz-dwc2 jz-dwc2: cgu clk gate get error
[ 0.149392] cfg80211: Calling CRDA to update world regulatory domain
[ 0.155850] jz-dwc2 jz-dwc2: regulator vbus get error
[ 0.160907] DWC IN OTG MODE
[ 0.313253] sft id =========================off
[ 0.317886] dwc2 dwc2: Keep PHY ON
[ 0.321259] dwc2 dwc2: Using Buffer DMA mode
[ 0.524215] dwc2 dwc2: Core Release: 3.00a
[ 0.539752] dwc2 dwc2: dwc2_core_reset() HANG! Soft Reset GRSTCTL=0x80000001
[ 0.558314] dwc2 dwc2: dwc2_core_reset() HANG! Soft Reset GRSTCTL=0x80000001
[ 0.565424] dwc2 dwc2: DesignWare USB2.0 High-Speed Host Controller
[ 0.571771] dwc2 dwc2: new USB bus registered, assigned bus number 1
[ 0.579269] hub 1-0:1.0: USB hub found
[ 0.583015] hub 1-0:1.0: 1 port detected
[ 0.587230] dwc2 dwc2: DWC2 Host Initialized
[ 0.591746] NET: Registered protocol family 2
[ 0.596838] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.603819] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.610203] TCP: Hash tables configured (established 512 bind 512)
[ 0.616542] TCP: reno registered
[ 0.619742] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.625702] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.632340] NET: Registered protocol family 1
[ 0.637119] RPC: Registered named UNIX socket transport module.
[ 0.643054] RPC: Registered udp transport module.
[ 0.647898] RPC: Registered tcp transport module.
[ 0.652590] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.659756] freq_udelay_jiffys[0].max_num = 10
[ 0.664244] cpufreq udelay loops_per_jiffy
[ 0.668602] 12000 59506 59506
[ 0.671868] 24000 119013 119013
[ 0.675364] 60000 297533 297533
[ 0.678755] 120000 595066 595066
[ 0.682286] 200000 991778 991778
[ 0.685927] 300000 1487667 1487667
[ 0.689561] 600000 2975334 2975334
[ 0.693268] 792000 3927441 3927441
[ 0.697011] 1008000 4998561 4998561
[ 0.700773] 1200000 5950668 5950668
[ 0.710943] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.718009] jffs2: version 2.2. © 2001-2006 Red Hat, Inc.
[ 0.724071] msgmni has been set to 75
[ 0.729344] io scheduler noop registered
[ 0.733287] io scheduler cfq registered (default)
[ 0.740211] jz-uart.1: ttyS1 at MMIO 0x10031000 (irq = 58) is a uart1
[ 0.748766] console [ttyS1] enabled, bootconsole disabled
[ 0.764789] brd: module loaded
[ 0.770303] loop: module loaded
[ 0.774457] zram: Created 2 device(s) ...
[ 0.778708] logger: created 256K log 'log_main'
[ 0.784263] jz SADC driver registeres over!
[ 0.789745] jz TCU driver register completed
[ 0.794747] the id code = 1c7017, the flash name is EN25QH64
[ 0.800622] JZ SFC Controller for SFC channel 0 driver register
[ 0.806848] 6 cmdlinepart partitions found on MTD device jz_sfc
[ 0.812987] Creating 6 MTD partitions on "jz_sfc":
[ 0.817979] 0x000000000000-0x000000040000 : "boot"
[ 0.823587] 0x000000040000-0x0000004c0000 : "appfs"
[ 0.829307] 0x0000004c0000-0x000000670000 : "kernel"
[ 0.835120] 0x000000670000-0x000000770000 : "root"
[ 0.840707] 0x000000770000-0x000000780000 : "hwconfig"
[ 0.846724] 0x000000780000-0x000000800000 : "config"
[ 0.852480] SPI NOR MTD LOAD OK
[ 0.855875] tun: Universal TUN/TAP device driver, 1.6
[ 0.861115] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.867666] Bus Mode Reg after reset: 0x00020101, cnt=0
[ 0.876463] libphy: jz_mii_bus: probed
[ 0.880451] =======>gmacdev = 0x821f7800<================
[ 0.886132] =========>gmacdev->MacBase = 0xb34b0000 DmaBase = 0xb34b1000
[ 0.893082] Bus Mode Reg after reset: 0x00020101, cnt=0
[ 0.900186] jz_mac jz_mac.0: JZ on-chip Ethernet MAC driver, Version 1.0
[ 0.907400] usbcore: registered new interface driver zd1201
[ 0.913553] jzmmc_v1.2 jzmmc_v1.2.0: vmmc regulator missing
[ 0.954708] jzmmc_v1.2 jzmmc_v1.2.0: register success!
[ 0.960433] TCP: cubic registered
[ 0.963928] NET: Registered protocol family 17
[ 0.969644] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 0.976928] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 0.989247] VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
[ 0.997237] Freeing unused kernel memory: 256K (804d0000 - 80510000)
mdev is ok......
IPC login: /dev/mtdblock5
input sensor is ov2735b
[ 2.263436] @@@@ tx-isp-probe ok @@@@@
[ 2.318289] at24 1-0050: 2048 byte 24c16 EEPROM, writable, 16 bytes/write
[ 2.338201] jz_codec_register: probe() successful!
[ 2.964153] dma dma0chan24: Channel 24 have been requested.(phy id 7,type 0x06 desc a1899000)
[ 2.973496] dma dma0chan25: Channel 25 have been requested.(phy id 6,type 0x06 desc a189e000)
[ 2.998718] Bus Mode Reg after reset: 0x00020101, cnt=0
route: SIOCDELRT: No such process
interface info here...
iface = eth0
inet = static
ip = 192.168.1.199
netmask = 255.255.255.0
gateway = 192.168.1.1
dns = 192.168.1.1
killall: udhcpc: no process killed
killall: wpa_supplicant: no process killed
iface eth0 static
interface, static ip...
hwclock: can't open '/dev/misc/rtc': No such file or directory
IPCam Init...
building date: Apr 23 2018: 17:52:34
y=2018,m=3,d=29
yst1 = 1
[ 4.902905] name : i2c-gpio1 nr : 1
[ 4.908839] name : i2c0 nr : 0
[ 4.994060] sensor_read: addr=0x2 value = 0x27
[ 4.999324] sensor_read: addr=0x3 value = 0x35
[ 5.004466] sensor_read: addr=0x4 value = 0x7
[ 5.009470] sensor_read: addr=0x4 value = 0x7
[ 5.014131] info: success sensor find : ov2735b
[ 5.018888] misc sinfo_release
====>>. sensor: 0
IspInit start
[ 5.070744] set sensor gpio as PA-low-10bit
[ 5.154917] ov2735 chip found @ 0x3c (i2c0)
funcs: 0x0
InitIsp success
__framesource_init ok
__encoder_group_init ok
__osd_group_init ok
__device_bind ok
enter night mode...
enter day mode...
jv_sensor_nocolour 0
IMP_ISP_Tuning_SetTemperDnsAttr ret 0
mountpoint: /progs/rec/00/: No such file or directory
umount failed, error is No such file or directory
No Disk
mac is same one
check inet: static
__bSupport_WIFI_check=0
**********************YSIZE:16
mptzosd_init: af not support!
zrtsp start......
dooralarm not support
Read config file /etc/conf.d/jovision//default/system.cfg failed.
schedule1 0
schedule2 0
sch1TimeStart 6:0
sch1TimeEnd 18:0
sch2TimeStart 18:0
sch2TimeEnd 6:0
IP auto adapt open!
utl_net_lan_init(266) dev_id :c96a71
Start create MLAN
jv_mdetect_stop ok
-----call jv_privacy_stop----chn 0-----
IMP_FrameSource_SetChnAttr chn=0, w=1920, h=1080, scaler(1920, 1080), ret=0
i265e[info]: Main profile, Level-4 (Main tier)
jv_stream_start ok venc=0, w=1920, h=1080, fps=25/1, gop=50, bitrate=2048
IMP_FrameSource_SetChnAttr chn=1, w=640, h=480, scaler(640, 480), ret=0
i265e[info]: Main profile, Level-3 (Main tier)
jv_stream_start ok venc=1, w=640, h=480, fps=25/1, gop=50, bitrate=546
jv_mdetect_stop ok
jv_osddrv_create chn=0, handle=0, rgnHandle=0, (16, 1008), w=152, h=56
jv_osddrv_create chn=0, handle=1, rgnHandle=1, (1440, 16), w=464, h=56
jv_osddrv_create chn=1, handle=2, rgnHandle=2, (8, 448), w=56, h=24
jv_osddrv_create chn=1, handle=3, rgnHandle=3, (472, 8), w=160, h=24
mprivacy_flush chn=0, enable=0
IMP_Encoder_SetChnAttrRcMode(chn 1) ret 0
IMP_Encoder_SetChnFrmRate(chn 1) ret 0
IMP_Encoder_SetGOPSize(chn 1) ret 0
IMP_Encoder_SetChnHSkip(chn 1) ret 0
jv_steam_set_attr (chn 1): fps=25/1, gop=50, bitrate=546
system: killall thttpd
killall: thttpd: no process killed
system: /progs/bin/thttpd -d /progs/html/ -c "/cgi-bin/*|/onvif/*" -u root -T utf-8&
jv_mdetect_stop ok
Failed open /etc/conf.d/jovision/presetpos.cfg, because: No such file or directory
NO support Af!
NOt support pu&c!
jv_sensor_brightness 128
jv_sensor_contrast 128
jv_sensor_sharpness 128
jv_sensor_saturation 128
new CSWorker = 0
jvserver************v2.0.82.3[private:v2.0.81.38 20171114.1] (build 2018-1-23 10:36:57)
================ Init YST first ok(SQ492134513).
AddThreadID..........threadname:CheckDbgReq,thread id: 192
AddThreadID..........threadname:CloudStorageClearProc,thread id: 193
AddThreadID..........threadname:CloudStorageFilesProc,thread id: 194
AddThreadID..........threadname:WorkProc,thread id: 190
AddThreadID..........threadname:ListenProcTCP,thread id: 191
AddThreadID..........threadname:ListenProc,thread id: 188
AddThreadID..........threadname:GetIPNatProc,thread id: 189
AddThreadID..........threadname:SpCheckProc,thread id: 187
AddThreadID..........threadname:GetPositionProc,thread id: 186
AddThreadID..........threadname:SetUpnpProc,thread id: 185
+++++++++++++++++create socket success m_SocketRawBC:35
### tinyonvif built: Nov 22 2017: 10:02:41
ovdistar
gp.bRunning=1
system: sync
AddThreadID..........threadname:YSTProc,thread id: 199
AddThreadID..........threadname:WaitForPackage,thread id: 197
AddThreadID..........threadname:CheckNatProc,thread id: 198
AddThreadID..........threadname:LANToolProc,thread id: 196
AddThreadID..........threadname:SendProc,thread id: 202
AddThreadID..........threadname:RecvProc,thread id: 203
AddThreadID..........threadname:SCHCANNAL::GTProc,thread id: 201
AddThreadID..........threadname:SCHCANNAL::GTProc,thread id: 204
AddThreadID..........threadname:SendProc,thread id: 205
AddThreadID..........threadname:RecvProc,thread id: 206
AddThreadID..........threadname:BCProc,thread id: 207
AddThreadID..........threadname:SCHCANNAL::GTProc,thread id: 208
AddThreadID..........threadname:SendProc,thread id: 209
AddThreadID..........threadname:RecvProc,thread id: 210
AddThreadID..........threadname:SCHCANNAL::GTProc,thread id: 211
AddThreadID..........threadname:SendProc,thread id: 212
AddThreadID..........threadname:RecvProc,thread id: 213
AddThreadID..........threadname:LANSerchProc,thread id: 214
===ov pid:215
system: echo 3 > /proc/sys/vm/drop_caches
watchdog enabled, timeout=30
[ 7.893871] libphy: 0:00 - Link is Up - 100/Full
**************set net to eth0**************
set net card eth0
JVN_SetLocalNetCard eth0
**************eth0 setting static**************
ip: c0a801c7, gw: c0a80101, mask:ffffff00
file fd:42
system: killall udhcpc; killall wpa_supplicant;
Channel:2 -- Client:43 [192.168.1.168:65053], type:1, connect success!
found some client(s) do not support smart venc
start ntp ntp.fudan.edu.cn
Trun to DayMode...
enter day mode...
system: /progs/networkcfg.sh &
set isp fps 25/1, ret 0
ovdistop
join ok.
iface = eth0
inet = static
ip = 192.168.1.199
dns = 192.168.1.1
iface eth0 static
ovdistar
ntp time receive 0, -1
ntp time receive 1, -1
ntp time receive 2, 0
校时成功
IPC login: root
Password:
Login incorrect
IPC login: root
Password:
Login incorrect
IPC login:
Login timed out after 60 seconds
IPC login: ▒յ▒▒▒▒▒▒▒▒RTMP 38 ▒
----------------cloud storage switch off------------------从上电开始计时,直到客户端出现视频,大概22s,其中客户端大部分时间显示连接中,因此该时间还是比较准确的。
几个问题:1.有谁知道账户和密码,随便填了几个都不行;2.尚维的rtsp地址是多少?
该处链接https://www.jiangyu.org/port-and-rtsp-address-of-several-ipcams/所说地址测试无效。
最近编辑记录 cheng (2018-11-13 00:15:19)
支持H.264及H.265编码
采用官方客户端CMS2.0,子码流粗略估计延时在500ms左右。
上面对比的雄迈模组应该用的是Hi3518EV100。
正常晃动摄像头,采用H.265编码传输,子码流网络占用在50KB/s以内。
感谢楼主的分享和评测!
关于设备的IP地址应该可以通过 onvif 协议搜索出来, 淘宝上面的硬盘录像机有这个功能, 或者电脑上安装某些录像软件也可以。
感谢楼主的分享和评测!
昨晚直接对官方客户端抓包没提取出来rtsp,今天有时间试试onvif
cheng wrote:
感谢楼主的分享和评测!
期待更多进展!
没有bsp和工具链,基本没得玩
dbskcnc wrote:
没有bsp和工具链,基本没得玩
只能等了
cheng wrote:
dbskcnc wrote:
没有bsp和工具链,基本没得玩
只能等了
可以找君正签个nda拿, 要等就很久了
采用onvif协议获取rtsp地址,利用ONVIF Device Manager,拿到rtsp地址
主码流:rtsp://192.168.1.199:5544/live0
辅码流:rtsp://192.168.1.199:5544/live1
经过测试,主辅码流靠字符段截取判断,如rtsp://192.168.1.199:5544/live11就是rtsp://192.168.1.199:5544/live1。
用vlc或potplayer可以直接播放:
播放器优化一下300ms以内应该没什么问题。常规操作到此为止,看看能不能搞到sdk。
看得我都蠢蠢欲动了,想想家里还有那么多吃灰的板子还是忍几天吧
多忍几天。。。
T30 分为
T30N (Normal)
T30L (Lite)简化版本
T30X (eXtra)增强版
T30A (Ai) AI版本
T30Z (Zoro)
T30N 为标准配置全功能版本,900Mh主频,内置512Mbit DDR, 可扩展第三方算法(需要购买授权)
T30L 内置512Mbit DDR ,不具备快启动,750Mhz 主频,算法没有高需求的基本视频应用市场。
T30X 内存增强版本,除拥有T30N的所有功能,内存1G bit
T30A 除具有N的所有功能外,内存1G ,可做智能视频应用,Mic阵列应用。
T30Z为电池特别版本,专为电池类应用
据说 root 的 密码是 IPCam@sw
v5!就是这个密码
IPC login: root
Password:
Dec 6 22:23:05 login[247]: root login on 'console'
[root@IPC:~]# ls /
bin home media opt root sys usr
dev lib mnt proc run system var
etc linuxrc nfsroot progs sbin tmp wifi
[root@IPC:~]# cat /home/startup.sh
#! /bin/sh
export LD_LIBRARY_PATH='/home/libs'
mount /tmp /progs/html/cgi-bin/snapshot
[ -d /progs/rec ] && mount_as_tmpfs /progs/rec
#fw_printenv
cp /home/fw_env.config /tmp/
[ -d /var/lock ] || mkdir /var/lock
#get /dev/mtdblockN with mtd name
getmtd()
MTDNAME=$1
temp=`grep $MTDNAME /proc/mtd`
temp=${temp%%:*}
echo ${temp/mtd/\/dev\/mtdblock}
#mtd3: 00080000 00010000 "config"
CONFIG_MTD=`getmtd \"config\"`
echo $CONFIG_MTD
mkdir /tmp/conf.d
mount -t jffs2 $CONFIG_MTD /tmp/conf.d/
[ -d /etc/conf.d/jovision ] || mkdir /etc/conf.d/jovision
[ -d /etc/conf.d/fixed ] || mkdir /etc/conf.d/fixed
[ -d /etc/conf.d/jovision/network ] || mkdir -p /etc/conf.d/jovision/network
echo "256000" > /proc/sys/net/core/wmem_default #500KB默认缓存
echo "512000" > /proc/sys/net/core/wmem_max #1000KB最大缓存
#echo "512000" > /proc/sys/net/core/rmem_default #500KB默认缓存
#echo "1024000" > /proc/sys/net/core/rmem_max #1000KB最大缓存
#设置保留内存大小
echo 512 > /proc/sys/vm/min_free_kbytes
MODULE_DIR=$(uname -r)
mkdir -p /tmp/modules/${MODULE_DIR}
# zram swap
#echo 100 > /proc/sys/vm/swappiness
#echo 16777216 > /sys/block/zram0/disksize
#mkswap /dev/zram0
#swapon /dev/zram0
#echo 6291456 > /sys/block/zram1/disksize
#mkfs.vfat /dev/zram1
#mkdir /tmp/zram_disk
#mount -t vfat /dev/zram1 /tmp/zram_disk/
#设置栈大小
ulimit -s 4096
cd /home/ipc_drv
#default value of SENSOR
SENSOR=ov2735b
#set the value of SENSOR
if [ -f /etc/conf.d/jovision/sensor.sh ] ; then
. /etc/conf.d/jovision/sensor.sh
echo SENSOR=$SENSOR > /etc/conf.d/jovision/sensor.sh
fi
./loaddrv ${SENSOR}
#wifi
[ ! -f /home/wifi/vt9271.ko ] || insmod /home/wifi/vt9271.ko
[ ! -f /home/wifi/8188fu.ko ] || insmod /home/wifi/8188fu.ko
if [ -f /home/wifi/mt7601Usta.ko ] ; then
insmod /home/wifi/mt7601Usta.ko
fi
#setMAC
if [ -f /etc/conf.d/jovision/network/mac.cfg ] ; then
. /etc/conf.d/jovision/network/mac.cfg
fi
#配置网络参数
#telnetd&
hwclock -s -u
cp /progs/bin/mySystem /tmp/
/tmp/mySystem &
if [ -f /etc/conf.d/startup.sh ] ; then
exit
fi
cp /progs/bin/sctrl /tmp
/tmp/sctrl
reboot
[root@IPC:~]# ls /progs/bin/
mySystem sctrl thttpd webproxy
[root@IPC:~]#离线
之前的图里ircut位置没插好,正确连线见下图右上部:
大神们,第一次接触,这个板子怎么连接到电脑上,我是要在这个板子上把编译好的程序跑一下做测试。
用串口连电脑
jimmy wrote:
用串口连电脑
淘宝上找到了,先买过来试试,谢谢指教
线已经买回来了,研究了半天,还想跟大神请教一下,按照楼主的方式接线,串口线的位置是哪个
jimmy wrote:
用串口连电脑
多谢多谢,看到了这个了,还得再买针脚
一楼第六个图
jimmy wrote:
用串口连电脑
谢谢晕哥,先回去试试用导线,不行再买排针。
直接用导线焊接也可以。
Timer init
CLK stop
PLL init
pll_init:411
cppcr is 03d01060
CPM_CPAPCR 07c0504d
cppcr is 02900860
CPM_CPMPCR 07c0882d
cppcr is 03100860
CPM_CPVPCR 0310086d
cppcr is 03100860
CPM_CPEPCR 0310086d
cppcr 0x9a773310
apll_freq 750000000
ddrfreq 500000000
cclk 750000000
l2clk 375000000
h0clk 200000000
h2clk 200000000
pclk 100000000
CLK init
SDRAM init
sdram init start
phy reg = 0x00000007, CL = 0x00000007启动到这里就停了,是不是Uboot不对还是芯片故障
