楼主 # 2021-07-15 14:55:39
luott
求助 F1C200s配置UART2只能发,不能收,linux内核版本5.2
串口0和串口1能正常工作
dts配置
&uart0 {
	pinctrl-names = "default";
	pinctrl-0 = <&uart0_pe_pins>;
&uart1 {
	pinctrl-0 = <&uart1_pa_pins>;
&uart2 {
	pinctrl-0 = <&uart2_pe_pins>;
dtsi配置
uart0_pe_pins: uart0-pe-pins {
        pins = "PE0", "PE1";
        function = "uart0";
uart1_pa_pins: uart1-pa-pins {
        pins = "PA2", "PA3";
        function = "uart1";
uart2_pe_pins: uart2-pe-pins {
        pins = "PE7", "PE8";
        function = "uart2";
启动日志
[    0.364037] printk: console [ttyS0] disabled
[    0.384360] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 23, base_baud = 6250000) is a 16550A
[    0.775548] printk: console [ttyS0] enabled
[    0.780419] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pa not found, using dummy regulator
[    0.813538] 1c25400.serial: ttyS1 at MMIO 0x1c25400 (irq = 24, base_baud = 6250000) is a 16550A
[    0.844140] 1c25800.serial: ttyS2 at MMIO 0x1c25800 (irq = 25, base_baud = 6250000) is a 16550A
#1 2021-07-15 15:02:56
已发帖子: 3,409
Re: 求助 F1C200s配置UART2只能发,不能收,linux内核版本5.2
硬件有没有问题呢?换块板子试一试。
PE7/8引脚有没有别的复用占用呢?
楼主 #2 2021-07-15 15:14:54
luott
正准备换一块板子试一下
楼主 #3 2021-07-15 15:22:47
luott
硬件问题换了块歪朵拉的tiny200就没问题
#4 2021-07-15 15:25:13
已发帖子: 3,409
