楼主 # 2022-08-07 18:44:52
tevada2010
已发帖子: 54
v3s+ili9341引导至系统时不显示图像。
我正在使用ili9341,现在我可以显示图像了。 但是我希望它从我启动系统的那一刻起就显示出来,我该怎么办?
想在开机进入系统时这样显示 该怎么办
[    1.055335] usbhid: USB HID core driver
[    1.059383] fbtft_of_value: buswidth = 8
[    1.063311] fbtft_of_value: debug = 0
[    1.066969] fbtft_of_value: rotate = 90
[    1.070841] fbtft_of_value: fps = 30
[    1.084058] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.095947] mmc0: new high speed SD card at address e624
[    1.103110] mmcblk0: mmc0:e624 SU02G 1.84 GiB
[    1.108669] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[    1.119178]  mmcblk0: p1 p2
[    1.125484] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[    1.134200] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[    1.141570] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[    1.147100] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[    1.152699] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[    1.158256] mmc1: new high speed SDIO card at address 0001
[    1.364748] random: fast init done
[    1.400120] Console: switching to colour frame buffer device 40x30
[    1.407009] graphics fb0: fb_ili9341 frame buffer, 320x240, 150 KiB video memory, 16 KiB buffer memory, fps=33, spi0.0 at 48 MHz
[    1.420661] sun4i-codec 1c22c00.codec: ASoC: codec-analog@01c23000 not registered
[    1.428304] sun4i-codec 1c22c00.codec: Failed to register our card
最近编辑记录 tevada2010 (2022-08-07 18:45:59)
#1 2022-08-07 18:57:48
已发帖子: 3,409
Re: v3s+ili9341引导至系统时不显示图像。
要在 uboot阶段显示开机画面?
楼主 #2 2022-08-07 20:28:05
tevada2010
已发帖子: 54
哇酷小二 wrote:
要在 uboot阶段显示开机画面?
是的
#3 2022-08-07 21:07:12
已发帖子: 3,409
tevada2010 wrote:
哇酷小二 wrote:
要在 uboot阶段显示开机画面?
是的
有点难度,得在uboot里面实现linux driver里面那个 tftlcd 之类的驱动。
楼主 #4 2022-08-07 21:19:48
tevada2010
已发帖子: 54
哇酷小二 wrote:
tevada2010 wrote:
哇酷小二 wrote:
要在 uboot阶段显示开机画面?
是的
我按照此链接中的步骤在 uboot 上安装了驱动程序。 但是在启动到系统时它不显示结果。
https://whycan.com/t_6413.html
#5 2022-08-07 21:27:35
已发帖子: 3,409
uboot 显示 建议先不要搞了,目前你应该还搞不定 (逃
楼主 #6 2022-08-07 21:52:44
tevada2010
已发帖子: 54
你什么意思?我不明白。
楼主 #7 2022-08-10 23:02:52
tevada2010
已发帖子: 54
Help me please.
楼主 #8 2022-08-12 21:31:35
tevada2010
已发帖子: 54
完毕
#9 2022-09-04 14:58:46
744219909
已发帖子: 31
试看下这个https://blog.csdn.net/qq_46604211/article/details/116449891
