楼主 #1 2018-12-19 10:55:14
pqfeng
已发帖子: 129
请教一下,为什么我有库,却不能编译通过,说找不到库。谢谢。
-rwxr-xr-x 1 root root 964991 Oct 18 17:59 libjpeg.so.9.1.0
-rwxr-xr-x 1 root root 431620 Oct 18 17:58 libm-2.23.so
lrwxrwxrwx 1 root root 12 Oct 18 17:58 libm.so.6 -> libm-2.23.so
-rwxr-xr-x 1 root root 63364 Oct 18 17:58 libnsl-2.23.so
lrwxrwxrwx 1 root root 14 Oct 18 17:58 libnsl.so.1 -> libnsl-2.23.so
-rwxr-xr-x 1 root root 22060 Oct 18 17:59 libnss_dns-2.23.so
lrwxrwxrwx 1 root root 18 Oct 18 17:58 libnss_dns.so.2 -> libnss_dns-2.23.so
-rwxr-xr-x 1 root root 34412 Oct 18 17:58 libnss_files-2.23.so
lrwxrwxrwx 1 root root 20 Oct 18 17:59 libnss_files.so.2 -> libnss_files-2.23.so
-rwxr-xr-x 1 root root 115588 Oct 18 17:58 libpthread-2.23.so
lrwxrwxrwx 1 root root 18 Oct 18 17:58 libpthread.so.0 -> libpthread-2.23.so
-rwxr-xr-x 1 root root 63216 Oct 18 17:58 libresolv-2.23.so
lrwxrwxrwx 1 root root 17 Oct 18 17:58 libresolv.so.2 -> libresolv-2.23.so
-rwxr-xr-x 1 root root 30676 Oct 18 17:58 librt-2.23.so
lrwxrwxrwx 1 root root 13 Oct 18 17:58 librt.so.1 -> librt-2.23.so
-rwxr-xr-x 1 root root 945 Oct 18 17:59 libts.la
-rwxr-xr-x 1 root root 946 Oct 18 17:59 libts.lai
-rwxr-xr-x 1 root root 12294 Oct 18 17:59 libts.so
-rwxr-xr-x 1 root root 12294 Oct 18 17:59 libts.so.0
-rwxr-xr-x 1 root root 12294 Oct 18 17:59 libts.so.0.8.0
-rwxr-xr-x 1 root root 17980 Oct 18 17:59 libutil-2.23.so
lrwxrwxrwx 1 root root 15 Oct 18 17:58 libutil.so.1 -> libutil-2.23.so
drwxr-xr-x 3 root root 4096 Dec 19 09:09 share
pqfeng@ubuntu:/opt/rootfs/lib$ cd /home/pqfeng/kadiuart/
pqfeng@ubuntu:~/kadiuart$ ls
bitmap.c configtxt.c dataproc.c ebfont.h jconfig.h jpegcodec.o libfile.o libts.lai message.h osdecode.o qrcnv.o rtfdecode.o ts.c utf8decode.o
bitmap.h configtxt.h dataproc.h ebfont.o jdct.h jpeg.h libjpeg.a libts.so modbus.c os.h qr_dwtable.h slidescreen.c tslib.h utf8table.c
bitmap.o configtxt.o dataproc.o gb23122unicode.c jerror.h jpegint.h libjpeg.la libuartscreen.a modbus.h psimage.h qr.h slidescreen.o ts.o utf8table.o
calibrate.c crc.h dispctrl.c gb23122unicode.o jinclude.h jpeglib.h libjpeg.lai Makefile modbus.o PY_code.h qr.o stackopea.c uartmain.c wordcodec.c
calibrate.o d2k_discrpit.c dispctrl.o HZ_input.c jmemsys.h Kadi_Set libjpeg.so memblock.c os_command.c qr.c qr_private.h stackopea.h uartmain.h wordcodec.o
common.h d2k_discrpit.o ebcommon.c HZ_input.o jmorecfg.h kdcommand.c libserial.c memblock.o os_command.o qrcmd.h qr_util.h stackopea.o uartmain.o
communication.c d2k_formatlast.c ebcommon.o imagebase.c jpegcodec.c kdcommand.o libserial.o messagecycle.c osdecode.c qrcnv.c rtfdecode.c toucharea.c utf8decode.c
communication.o d2k_formatlast.o ebfont.c imagebase.o jpegcodec.h libfile.c libts.la messagecycle.o osdecode.h qrcnv.h rtfdecode.h toucharea.o utf8decode.h
pqfeng@ubuntu:~/kadiuart$ make
arm-linux-gnueabihf-gcc -L/opt/rootfs/lib/ -L/opt/rootfs/lib/lib -L/opt/rootfs/lib/lib/ts -L. -lpthread -lm -lc -lts -ljpeg os_command.o kdcommand.o messagecycle.o d2k_formatlast.o memblock.o imagebase.o configtxt.o slidescreen.o utf8decode.o toucharea.o modbus.o d2k_discrpit.o ebcommon.o qrcnv.o bitmap.o qr.o osdecode.o HZ_input.o communication.o utf8table.o jpegcodec.o libfile.o ts.o gb23122unicode.o rtfdecode.o wordcodec.o ebfont.o libserial.o uartmain.o calibrate.o stackopea.o dataproc.o dispctrl.o -o kadiuart
kdcommand.o: In function `kdCmd_SQRT':
kdcommand.c:(.text+0x25b6): undefined reference to `sqrt'
kdcommand.c:(.text+0x25ea): undefined reference to `sqrt'
kdcommand.c:(.text+0x2622): undefined reference to `sqrt'
imagebase.o: In function `ImageRotate':
imagebase.c:(.text+0x1528): undefined reference to `sin'
imagebase.c:(.text+0x1556): undefined reference to `cos'
imagebase.o: In function `DrawArcToImg':
imagebase.c:(.text+0x2e90): undefined reference to `cos'
imagebase.c:(.text+0x2ee2): undefined reference to `sin'
imagebase.c:(.text+0x2f34): undefined reference to `cos'
imagebase.c:(.text+0x2f86): undefined reference to `sin'
imagebase.c:(.text+0x304c): undefined reference to `sqrt'
imagebase.c:(.text+0x310e): undefined reference to `sqrt'
imagebase.o: In function `DrawFillArcOnImg':
imagebase.c:(.text+0x40ac): undefined reference to `cos'
imagebase.c:(.text+0x40fe): undefined reference to `sin'
imagebase.c:(.text+0x4150): undefined reference to `cos'
imagebase.c:(.text+0x41a2): undefined reference to `sin'
imagebase.c:(.text+0x4286): undefined reference to `sqrt'
imagebase.c:(.text+0x4348): undefined reference to `sqrt'
imagebase.o: In function `MakeSectorMask':
imagebase.c:(.text+0x4882): undefined reference to `cos'
imagebase.c:(.text+0x48d4): undefined reference to `sin'
imagebase.c:(.text+0x4926): undefined reference to `cos'
imagebase.c:(.text+0x4978): undefined reference to `sin'
imagebase.c:(.text+0x4a64): undefined reference to `sqrt'
imagebase.c:(.text+0x4afe): undefined reference to `sqrt'
#2 2018-12-19 11:20:55
已发帖子: 9,492
Re: 请教一下,为什么我有库,却不能编译通过,说找不到库。谢谢。
glibc/uclibc 自带 libm 动态链接库,应该是操作问题吧.
做一个小的测试demo, 调用 sqrt() 试一试,看能否链接成功.
#3 2018-12-19 20:16:19
执念执战
已发帖子: 26
我之前编译licheepi nano 的裸机驱动也是math库找不到。网上搜了半天说是arm裸机不支持除法(还有其他说法,忘了),然后有教程。但是跟着弄了半天,没解决。所以自己从网上复制了一个math库的c语言实现方法,才通过的。就是旋转立方体那个源程序中的Mymath.c。不知对你有帮助么,如果是一样的问题的话,这么解决起来很快的。
#4 2018-12-20 06:53:52
basicdev
已发帖子: 159
这个应该不是裸奔,一般gcc都提供了 数学函数库 libm.a,感觉还是操作方面的原因
