楼主 # 2022-04-10 12:50:32
Gtc
求助lichee nano ESP8089问题
开机启动至modprobe esp8089.ko后ifconfig-a的串口输出如下:
U-Boot SPL 2018.01-05679-g013ca457fd-dirty (Mar 13 2022 - 21:52:41)
DRAM: 32 MiB
Trying to boot from MMC1
mmc_init: -95, time 22
Trying to boot from sunxi SPI
U-Boot 2018.01-05679-g013ca457fd-dirty (Mar 13 2022 - 21:52:41 +0800) Allwinner Technology
Model: Lichee Pi Nano
DRAM: 32 MiB
MMC: SUNXI SD/MMC: 0
SF: Detected xt25f128b with page size 256 Bytes, erase size 4 KiB, total 16 MiB
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
Net: No ethernet found.
No controllers found
Flattened Device Tree blob at 80c00000
Loading Device Tree to 816fb000, end 816fff3e ... OK
[ 0.000000] Linux version 4.15.0-rc8-licheepi-nano+ (gartonchan@gartonchan-virtual-machine) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #2 Thu Apr 7 20:03:17 HKT 2022
[ 0.000000] random: fast init done
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/mtdblock3 rw rootfstype=jffs2
[ 0.000000] Memory: 22648K/32768K available (6144K kernel code, 264K rwdata, 1464K rodata, 1024K init, 245K bss, 10120K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc2800000 - 0xff800000 ( 976 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc2000000 ( 32 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (7136 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 265 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 246 kB)
[ 0.000045] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000110] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000636] Console: colour dummy device 80x30
[ 0.000724] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[ 0.070222] pid_max: default: 32768 minimum: 301
[ 0.070522] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.070562] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.071960] CPU: Testing write buffer coherency: ok
[ 0.073565] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.076054] devtmpfs: initialized
[ 0.082507] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.082575] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.082817] pinctrl core: initialized pinctrl subsystem
[ 0.084752] NET: Registered protocol family 16
[ 0.086133] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.087844] cpuidle: using governor menu
[ 0.113442] SCSI subsystem initialized
[ 0.114014] usbcore: registered new interface driver usbfs
[ 0.114154] usbcore: registered new interface driver hub
[ 0.114327] usbcore: registered new device driver usb
[ 0.114722] pps_core: LinuxPPS API ver. 1 registered
[ 0.114747] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.114803] PTP clock support registered
[ 0.115285] Advanced Linux Sound Architecture Driver Initialized.
[ 0.117310] clocksource: Switched to clocksource timer
[ 0.142714] NET: Registered protocol family 2
[ 0.144100] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.144174] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.144223] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.144488] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.144544] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.145002] NET: Registered protocol family 1
[ 0.146177] RPC: Registered named UNIX socket transport module.
[ 0.146215] RPC: Registered udp transport module.
[ 0.146231] RPC: Registered tcp transport module.
[ 0.146247] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.148548] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.150310] Initialise system trusted keyrings
[ 0.150840] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[ 0.167799] NFS: Registering the id_resolver key type
[ 0.167880] Key type id_resolver registered
[ 0.167901] Key type id_legacy registered
[ 0.168010] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.182365] Key type asymmetric registered
[ 0.182403] Asymmetric key parser 'x509' registered
[ 0.182597] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.182626] io scheduler noop registered
[ 0.182643] io scheduler deadline registered
[ 0.183438] io scheduler cfq registered (default)
[ 0.183469] io scheduler mq-deadline registered
[ 0.183487] io scheduler kyber registered
[ 0.184567] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[ 0.194303] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.357930] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.364349] console [ttyS0] disabled
[ 0.384583] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 23, base_baud = 6250000) is a 16550A
[ 0.861072] console [ttyS0] enabled
[ 0.871487] panel-simple panel: panel supply power not found, using dummy regulator
[ 0.880765] SCSI Media Changer driver v0.25
[ 0.888462] m25p80 spi0.0: xt25f128b (16384 Kbytes)
[ 0.893413] 4 ofpart partitions found on MTD device spi0.0
[ 0.899003] Creating 4 MTD partitions on "spi0.0":
[ 0.903815] 0x000000000000-0x000000100000 : "u-boot"
[ 0.911402] 0x000000100000-0x000000110000 : "dtb"
[ 0.918660] 0x000000110000-0x000000510000 : "kernel"
[ 0.925995] 0x000000510000-0x000001000000 : "rootfs"
[ 0.934334] libphy: Fixed MDIO Bus: probed
[ 0.938726] usbcore: registered new interface driver rtl8xxxu
[ 0.944587] usbcore: registered new interface driver rndis_wlan
[ 0.950737] usbcore: registered new interface driver asix
[ 0.956232] usbcore: registered new interface driver ax88179_178a
[ 0.962494] usbcore: registered new interface driver cdc_ether
[ 0.968488] usbcore: registered new interface driver net1080
[ 0.974226] usbcore: registered new interface driver rndis_host
[ 0.980298] usbcore: registered new interface driver cdc_subset
[ 0.986298] usbcore: registered new interface driver zaurus
[ 0.992104] usbcore: registered new interface driver cdc_ncm
[ 0.997823] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.004336] ehci-platform: EHCI generic platform driver
[ 1.009877] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.016094] ohci-platform: OHCI generic platform driver
[ 1.021767] usbcore: registered new interface driver usb-storage
[ 1.028780] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 1.037820] i2c /dev entries driver
[ 1.097435] sunxi-mmc 1c0f000.mmc: base:0x99fdc2b5 irq:19
[ 1.104788] usbcore: registered new interface driver usbhid
[ 1.110475] usbhid: USB HID core driver
[ 1.131790] NET: Registered protocol family 17
[ 1.136668] Key type dns_resolver registered
[ 1.143124] Loading compiled-in X.509 certificates
[ 1.158098] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc073a178)
[ 1.166846] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc073945c)
[ 1.174632] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.181283] [drm] No driver support for vblank timestamp query.
[ 1.197625] mmc0: queuing unknown CIS tuple 0x01 (3 bytes)
[ 1.204873] mmc0: queuing unknown CIS tuple 0x1a (5 bytes)
[ 1.208095] mmc0: queuing unknown CIS tuple 0x1b (8 bytes)
[ 1.210504] mmc0: queuing unknown CIS tuple 0x80 (1 bytes)
[ 1.210583] mmc0: queuing unknown CIS tuple 0x81 (1 bytes)
[ 1.210650] mmc0: queuing unknown CIS tuple 0x82 (1 bytes)
[ 1.210708] mmc0: new high speed SDIO card at address 0001
[ 1.235268] Console: switching to colour frame buffer device 60x34
[ 1.297057] sun4i-drm display-engine: fb0: frame buffer device
[ 1.304156] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 1.313372] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.325222] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.331188] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.341256] hub 1-0:1.0: USB hub found
[ 1.345183] hub 1-0:1.0: 1 port detected
[ 1.350861] using random self ethernet address
[ 1.355328] using random host ethernet address
[ 1.361652] usb0: HOST MAC 6e:9d:4b:28:54:25
[ 1.366105] usb0: MAC d6:bc:46:f6:70:53
[ 1.370183] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.377737] g_cdc gadget: g_cdc ready
[ 1.382413] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.400211] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1.406949] ALSA device list:
[ 1.410031] #0: Loopback 1
[ 1.413792] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.422542] cfg80211: failed to load regulatory.db
[ 1.530222] random: crng init done
[ 2.498891] jffs2: notice: (1) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 2.519232] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[ 2.528083] devtmpfs: mounted
[ 2.535715] Freeing unused kernel memory: 1024K
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
Saving random seed: OK
Starting network: OK
Welcome to Buildroot
Lichee login: root
Password:
ls
esp8089.ko
modprobe esp8089
[ 53.621116]
[ 53.621116] EAGLE DRIVER VER:bdf5087c3deb
[ 53.621116]
[ 53.629318] ESP8089 reset via GPIO 0
[ 53.847792] esp_sdio_dummy_probe enter
[ 54.067421] esp_sdio_init power up OK
[ 54.343693] Unable to handle kernel NULL pointer dereference at virtual address 000004c4
[ 54.351887] pgd = 43663e9b
[ 54.354600] [000004c4] *pgd=00000000
[ 54.358270] Internal error: Oops: 17 [#1] ARM
[ 54.362622] Modules linked in: esp8089(+)
[ 54.366650] CPU: 0 PID: 5 Comm: kworker/u2:0 Not tainted 4.15.0-rc8-licheepi-nano+ #2
[ 54.374453] Hardware name: Allwinner suniv Family
[ 54.379403] Workqueue: esp_wkq sip_rxq_process [esp8089]
[ 54.384912] PC is at sip_rxq_process+0x6c/0xe68 [esp8089]
[ 54.390304] LR is at 0x60000013
[ 54.393444] pc : [<bf0038e8>] lr : [<60000013>] psr: 60000013
[ 54.399695] sp : c183be90 ip : 00000000 fp : bf039744
[ 54.404910] r10: bf00d07c r9 : c0d0d594 r8 : c1804000
[ 54.410126] r7 : 000004c0 r6 : c1b7f600 r5 : c180d2a0 r4 : c0d0d594
[ 54.416639] r3 : 00000011 r2 : c0d0d300 r1 : c0d0d588 r0 : c0d0d300
[ 54.423151] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 54.430269] Control: 0005317f Table: 80d20000 DAC: 00000053
[ 54.436008] Process kworker/u2:0 (pid: 5, stack limit = 0x004ba662)
[ 54.442262] Stack: (0xc183be90 to 0xc183c000)
[ 54.446622] be80: 00000000 60000013 c0cb8680 c0d01c00
[ 54.454793] bea0: 00000002 c181f400 c06955d8 c0695934 c181f430 c181f430 00005bcc 00000000
[ 54.462964] bec0: c181f674 c01375ac c0d0d300 c0d0d540 c013883c c01379c8 00000009 c0a09af0
[ 54.471136] bee0: c0d0d588 c181f400 c0d0d57c c181f400 c0a09af0 c0d01c00 00000000 c0cb8680
[ 54.479306] bf00: c183bf44 c06955d8 c19dc814 c0d0d594 c180d2a0 c1b7f600 00000000 c1804000
[ 54.487477] bf20: 00000000 00000088 c1804000 c0129a64 c1804014 c0a0e5c0 c180d2a0 c1804000
[ 54.495647] bf40: ffffe000 c1804014 c0a0e5c0 c180d2b8 00000088 c0129cc8 c181d0c0 00000000
[ 54.503818] bf60: ffffe000 c1807580 c181d0c0 00000000 c183a000 c180d2a0 c0129c78 c182deec
[ 54.511987] bf80: c1807598 c012ec54 c183a000 c181d0c0 c012eb38 00000000 00000000 00000000
[ 54.520154] bfa0: 00000000 00000000 00000000 c0107dc0 00000000 00000000 00000000 00000000
[ 54.528320] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 54.536489] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 55545445 df5555d5
[ 54.544900] [<bf0038e8>] (sip_rxq_process [esp8089]) from [<c0129a64>] (process_one_work+0x1d8/0x3ec)
[ 54.554140] [<c0129a64>] (process_one_work) from [<c0129cc8>] (worker_thread+0x50/0x5b8)
[ 54.562235] [<c0129cc8>] (worker_thread) from [<c012ec54>] (kthread+0x11c/0x134)
[ 54.569641] [<c012ec54>] (kthread) from [<c0107dc0>] (ret_from_fork+0x14/0x34)
[ 54.576863] Code: e59d2038 e59a3000 e59270a0 e3130002 (e5d73004)
[ 54.583097] ---[ end trace 0732291277270d40 ]---
[ 64.487384] resetting event timeout
[ 64.490914] esp_init_all failed: -110
[ 64.494570] first error exit
ifconfig -a
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
usb0 Link encap:Ethernet HWaddr D6:BC:46:F6:70:53
BROADCAST MULTICAST MTU:1500 Metric:1
目前打算用lichee nano做嵌入式linux相关的毕设,求大佬分析一下,如何解决
